跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
My Thunderbolt Port on my MacBook isn't working properly.
My Mid-2017 13in Macbook Pro charging port doesn't work. When I plug in my cable to charge my laptop, it charges and stops charging in intervals. When I use my cable and brick for my other devices, it charges so I know it's not my cable or brick its my laptop. Should I replace the 2 thunderbolt ports, if so please send me a link. I'm doing this to get ready for college!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
So here’s the tricky thing with your machine. The USB-C ports are soldered to the logic board, so they aren’t easily replacable. But I WOULD recommend giving them a good inspection anyway and clean them up with some isopropyl alcohol and a cotton swab. It could just be a dirty connection. You’ll need to take the logic board out to see them, but luckily this one is relatively painless (for a logic board) to remove.
这个答案有帮助吗?
得分 2
添加一条评论
It is pretty common for the pins on the USB-C ports to become damaged or corroded, so I would recommend removing the USB-C boards and inspecting them. If they look clean then the issue is probably with your battery or in the worse case scenario there could be an issue with the main logic board. Good luck!
这个答案有帮助吗?
得分 1
6条评论:
@zpl is right, this sounds like some kind of failure on the USB-C ports.
My advice is to order some ports off ebay alongside getting a kit from ifixit to replace the ports.
完成的
thank you guys! can you send me reliable links to the correct parts for it?
完成的
is this the correct port for my laptop? https://www.ebay.com/itm/166044942220?ha...
Let me know ASAP!
完成的
That looks right to me!
完成的
Thanks you. !
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Nathan G. 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 21
总计 397
