跳转到主内容
The Xiaomi Redmi 9A is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G25.
51 个问题 查看全部
Sering restart sendiri terus masuk ke main menu Terus berulang kali
Pas sudah di main menu hp langsung mulia nyala pas mau ke layar wallpaper ada lingkaran terus ke restart kembali begitu terus
Google translate:
It often restarts itself and then goes to the main menu over and over again
When you go to the main menu, the cellphone immediately turns on, when you want to go to the wallpaper screen, there is a circle and then it restarts again and so on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @tgrzann
Try the following:
Wipe the cache partition and check if the phone works OK
Here's the procedure:
Turn off your phone if it is on and then press the Power button and the Volume Up button (both together) to boot into the Recovery menu.
When the Recovery menu appears release the buttons.
Next use the Volume Up and/or the Volume Down button to move through the menu options and highlight Wipe Cache Partition, then press the Power button to select it
Confirm by selecting Yes and then wait for the cache to be cleared.
Once it has finished select Reboot system now to restart the phone.
DO NOT select wipe data /factory restore as this will erase all your data and downloaded apps and will reset the phone back to its factory default condition. It will be like when you first got it.
Google translate:
Coba yang berikut ini:
Hapus partisi cache dan periksa apakah ponsel berfungsi dengan baik
Berikut prosedurnya:
Matikan ponsel Anda jika dalam keadaan hidup lalu tekan tombol Daya dan tombol Volume Naik (keduanya bersamaan) untuk boot ke menu Pemulihan.
Saat menu Pemulihan muncul, lepaskan tombol.
Selanjutnya gunakan tombol Volume Naik dan/atau Volume Turun untuk menelusuri opsi menu dan menyorot Wipe Cache Partition, lalu tekan tombol Daya untuk memilihnya
Konfirmasikan dengan memilih Ya lalu tunggu hingga cache dibersihkan.
Setelah selesai pilih Reboot system now untuk me-restart telepon.
JANGAN pilih wipe data / factory recovery karena ini akan menghapus semua data dan aplikasi yang Anda unduh dan akan mengatur ulang ponsel kembali ke kondisi default pabrik. Ini akan seperti saat Anda pertama kali mendapatkannya.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tgr Zann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 119
