跳转到主内容
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
135 个问题 查看全部
A1989 MacBook Pro Screen Broken After Fall
Hi all, I have an A1989 13-inch Touch Bar MacBook Pro 2019 which fell and now has a broken screen with the backlight on. Mostly the screen is black but sometimes the display comes through in a messed up way (see the pictures which were all taken within a few minutes of each other). I plugged it in to an external monitor and the computer itself is thankfully working. The screen has struggled for a few weeks before it fell today, showing vertical and horizontal bars (I think from overheating?). I just wanted to ask if I have to give up hope on it, or if there is something I could still try short of replacing the whole screen (even if it's still cracked)? Thanks for any help in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Unfortunately your display is damaged beyond repair and the only way to fix it is to replace the display. Amazon sells decent quality screens for a good price if you want to repair it yourself its not too difficult just remember to get the correct color screen and disconnect the battery first and you will need a custom pentalobe screw driver to remove the old screen so make sure you have the right tools.
MacBook Pro A1989 A2159 A2289 A2251 2018 2019 2020 Year 13.3" Retina LCD Display Assembly EMC 3214 3358 3301 3456 3348 2560x1600
MacBook Pro 13" Touch Bar 2019 Screen Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabriel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 158
