跳转到主内容
Repair, disassembly, and troubleshooting information for the second-generation Apple Watch SE, released September 2022.
I need the adhesive to put my screen back in caseo
I dropped my watch it came apart now I need the adhesive to put it together. What kind do I get
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I'm pretty sure this one will work if you have the 44mm model: iFixit
and this one for 40mm: Apple Watch (40 mm Series 6) Adhesive Strip (ifixit.com)
Replace an adhesive strip compatible with the 44 mm case Series 4 or Series 5 Apple Watch model A1976, A1978, A2008, A2093, A2095, and A2157.图片
产品
Apple Watch (44 mm Series 4/5) Screen Adhesive
$6.99
Replace the adhesive strip compatible with 40 mm Series 6 Apple Watch models A2291, A2293, A2375.图片
产品
Apple Watch (40 mm Series 6) Screen Adhesive
$8.99
这个答案有帮助吗?
得分 1
2条评论:
I have a 38mm case will this fit. If it will I’ll purchase the tape.
完成的
No, I'm sorry, but you will need to purchase a 38mm one, I was confused, as if you have an Apple Watch SE 2, there are sizes 40 mm and 44 mm. The only watches with 38mm are the series 1, 2, and 3 watches. The series 3 looks very similar to the SE 2, so these adhesives should work for a 38 mm watch like yours: this one for series 1 and 2 and this one for series 3. You can check the size of your watch by flipping your watch upside down and looking around the heart rate sensor. Check this guide for more detail. https://support.apple.com/en-us/HT204507
完成的
添加一条评论
添加你的答案
Mary Glassford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 326
