跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Why won't my screen turn on?
I was finishing up replacing the SSD on my iMac. I tested the screen before applying the adhesive and it worked. Upon taking the screen back off to apply the adhesive, I think either the display or display power cable got slightly tugged. I didn't think it was an issue since it was very slight. But unfortunately the screen is not turning on (no backlight lit). Do you think it is just one of those cables broken (which is more likely?) And if so is there a way to track down that part as it's just a cable? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
To help figure out which shine a flashlight into the display at a sharp angle a poor man’s backlight. If you see your desktops icons the backlight cable is damaged if not the video data cable.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dominic MacIsaac 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 70
