跳转到主内容
All screwdrivers manufactured by iFixit and sold on iFixit.com
22 个问题 查看全部
Is there ball end hex for iFixit screwdriver? I can only see straight
Hi, is there ball end hex for iFixit screwdriver ?
I have iFixit 64 bits, and I can only see straight. I need a ball end to reach screw by an angle. Where can I buy these bits for iFixit screwdriver ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @chris44982
Looks like ifixit doesn't have ball end hex bits but perhaps you could use something like these (examples only) in conjunction with the 1/4" to 4 mm Driver Adapter in the kit.
Update (09/01/23)
Hi @chris44982
Here's an image taken from the ifixit Mako Driver Kit - 64 Precision Bits tool kit which I assume is the one you're referring to, showing the location of the 1/4" → 4mm driver adapter in the kit.
It's a bit hard to see but under each bit is an embossed description of what the bit is. You can see them more clearly in the zoomed in image I posted below. Why they didn't have the description in a different colour e.g. white, I don't know.
Also in the link for the toolkit I posted on the right side of the page is a link that shows the kit contents.
(click on image above)
Mako Driver Kit - 64 Precision Bits图片
产品
$39.95
这个答案有帮助吗?
得分 3
添加一条评论
Where the 1/4" to 4 mm driver adapter in the kit ?
Are we talking about the same kit ? This is my iFixit 64bit kit :
这个答案有帮助吗?
得分 0
2条评论:
Hi, I have got no reply, where the 1/4" to 4 mm driver adapter in the kit ?
完成的
@chris44982
I replied 5 days ago in my answer above - see the update 09/01/23
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 81
