跳转到主内容
加入维修社区 - 创建账户
No Power Not booting
Plug in magsafe charger indicator always green, fan not spinning, measured voltage across fuse on board with magsafe charger plugged in (it reads 19volts ), I'm pretty decent with fixing iPhone logic boards, this is my first with MacBook logic board.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’m impressed the logic board is so clean!
I do see an area that needs investigation around the DC - In Board connector.
At this point you need to grab the schematics and board view drawings to trace out the power rails. I’m suspecting your issue is within the MOSFET power switching logic. Using a DVM you should be able to see what’s happening. Often times the knock-off charger has damaged them.
这个答案有帮助吗?
得分 0
3条评论:
@danj thank you for the reply, I'll appreciate if you can point me in the right direction where I can get a good schematics for MacBook logic board
完成的
@n3dtech - Locate the logic board number it should be either 820-2530 or 820-2936 the images you posted are too blurry for me to ID.
Then search the internet for number and Schematic
完成的
Okay thanks.
完成的
添加一条评论
添加你的答案
n3d Tech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 156
