跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
203 个问题 查看全部
Wrong battery percentage being reported after battery change
Question:
Any ideas on how to fix so that the OS reports the correct battery percentage?
Context:
  • I changed the battery on my own.
  • The computer charges fine up to what is being reported by the OS as 100%.
  • After disconnecting the power cable the OS will soon report the battery percentage to be 1%.
  • I am able to run the computer fine on 1% for an hour or so.
  • Battery condition is reported as "normal" by the OS.
Symptom:
Update (08/29/23)
Thank you for your answer.
I just tried resetting SMC but it didn't help.
CoconutBattery when power cable is disconnected:
CoconutBattery when the power cable was just connected:
CoconutBattery when the power cable has been connected for 5 minutes:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would start off resetting SMC and then leave the system to charge over night fully powered off.
I would also down load this Gem of an App CoconutBattery let’s see what it tells us. Post a snapshot of the Apps main screen here so we can see it to.
Update (08/29/23)
@tedlindstroem - Not good! 😞
I would replace the battery again as it does look like the microcontroller within it is defective in this battery. Contact the seller to get a replacement.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ted Lindström 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 56
