The screen randomly Go's black but audio still plays.
It's model number is PN60F5300BFXZA.
IF I plug it in and out again it sometimes works for a bit but it will randomly go dark. I called a local repair shop and they said it's whole display should be replaced but I'm hoping it's just a conective issue.
I put a picture of the inside if that helps. I really don't want to pay 300 for repairs. And advice apreachiated
What is the video source? If you’re using a Roku/PlayStation/etc and it’s pumping out say 4k @ 60hz but your hdmi cable is only good for 4k @ 30 hz, this can cause the same issue as you’re describing. Go in your video source settings and manually decrease the video out and see if it stops.
由 JnCA 完成的
@giantgarry try to post the image with your question again. This time follow this guide 在已经存在的问题里加入图片
What have you checked and what have you tried?
No picture with sound is commonly caused by a bad Y-sustain board.
由 oldturkey03 完成的
@jnca there is a roku yes I will try that
由 giant garry 完成的
@giantgarry look into https://www.hdmi.org/spec/index
由 JnCA 完成的
