跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
165 个问题 查看全部
Occasionally flickering and green screen
Hi all, I am new to iFixit! Thanks all for wonderful question and answers!
My iPhone 11 pro max was once bited by my kid and camera over filter damaged. It may induce some water damage.
After that, the phone starts flickering and turn green.
Occaionally, the screen becomes normal (only top right corner problem). It seems tell me it is not the screen issue.
So, before I buy another screen to replace. May I know is it likely the screen problem or other hardware problem?
Thanks so much!!!
p.s. tried (1) reinstall iOS updated, (2) adjust brightness, (3) adjust autotone, etc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Yeah that's most likely a damaged screen, get it replaced. I'd recommend you buy a soft OLED panel as that's what's close to what the factory installed on the device. Hard OLED is cheaper but the OLED panel is thicker and it's more fragile. Then there's LCD panels which I do not recommend or offer in my shop. They require more current and the connector on the board wasn't designed to have that much current flow through it, so it ends up burning the display connector on the board in some cases.
这个答案有帮助吗?
得分 1
1条评论:
Thanks so much, it is my first time to hear about soft and hard OLED. I will do some research. Thanks.
完成的
添加一条评论
添加你的答案
Sam Choo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 87
