跳转到主内容
加入维修社区 - 创建账户
Sony WH-1000XM4 無線降噪耳罩式耳機維修拆解資訊。
Why are don't my headphones turn on and instead factory reset?
Every time I try to turn on my headphones they just blink 4 times and the have a long blue flash before turning back off. do you know how to fix them?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I had the same problem and finally managed to fix it, The headphone jack still worked fine with the headphones too, so I’ll share in case it helps someone else.
After doing a full factory reset (following the manual exactly), I could reconnect the device over Bluetooth. However, every time it powered off, the issue came back and I had to repeat the factory reset to use it again.
What actually fixed it for good was this:
  1. Perform a full factory reset so you can connect over Bluetooth.
  2. Once connected, open the Sony Connect app.
  3. Use the app to update the device’s software/firmware.
After updating the software via the Sony Connect app, the problem stopped happening and I no longer needed to factory reset it each time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
good fella 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 87
