跳转到主内容
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 个问题 查看全部
问题已关闭
Anti-glare airport module location confusion
Hi there,
I switched my optical drive to fit an hdd bay after upgrading to an SDD. Everything went smooth, but; my wifi stopped working. (The wifi symbol shows "No hardware installed"). I tried everything I can think of, resetting smc, pram etc., retracing my steps, making sure I reconnected all the cabled; no dice, the wifi card seems bust.
So, I decided; let's try and get a new airport card. But I'm confused where/what my airport card in my anti-glare model actually is.
This (MacBook Pro 15" Unibody Mid 2009 Upper Case Replacement step 36) guide says the card on top of my optical bay is my bluetooth / airport card, while the optical drive guide (MacBook Pro 15" Unibody Mid 2009 Optical Drive Replacement step 11) says it's just a bluetooth card.
Can anybody tell me if the card on top of my optical drive is in fact just a bluetooth card, or a bluetooth + airport card?
MacBook Pro 15" Unibody Mid 2009 Optical Drive图片
指南
难度:
中等
MacBook Pro 15" Unibody Mid 2009 Upper Case图片
指南
难度:
困难
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
on mine the small card located on the dvd drive is just the bluetooth, the wifi card was in the screens plastic clutch barrel. The screen on mine is the normal resolution (1440x900) but anti glare.
这个答案有帮助吗?
得分 1
添加一条评论
You may have removed the card inadvertently, or left a cable disconnected. Follow this similar Question for more information.
If this answer was helpful please remember to return an mark it Accepted.
这个答案有帮助吗?
得分 0
1条评论:
I naturally looked around iFixit and found that thread, but it provides the same confusion as iFixit's Guide's. Several posters say the Airport card is on the optical drive, others say it in the screen's clutch barrel...
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 677
