跳转到主内容
Brushes making ratcheting sound, not sucking up dirt
Recently my old roomba started making intermittent high pitched sound, along with a ratchety sound. It goes all over, and is not throwing an error, but the bin is empty afterward. Took it partially apart, blew all the accumulated dirt out, cleaned it up, but no improvement. Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
My advise is to check your seals and locate the source of the sound, my guess is if your seals get replaced that high pitched will go away, and as for the ratchety sound, make sure the dust bin is clear and take off the brush and clean everything behind it and potentially lubricate it just to be safe
这个答案有帮助吗?
得分 0
2条评论:
Actually the rachet sound is at the 2 brushes. I can manually turn them and they make that sound. I can't tell if they are sweeping when its going on its way, or immobile. But its not sucking anything up. I feel air out the back end, so there is flow,but no aspiration.
完成的
Have you unscrewed the brushes and looked at the back of them? Mine were nasty.
完成的
添加一条评论
添加你的答案
kim t 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 71
