跳转到主内容
Repair information, service manuals, and troubleshooting help for refrigerators manufactured by LG Electronics.
32 个问题 查看全部
Water shoots out of water dispenser instead of filling ice tray on LG
LG LFX31945ST /02
Water comes out of dispenser instead of filling ice tray? Faulty inlet valve?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @chipabrams
Does any water enter the ice tray at all?
It could be a faulty water dispenser valve, stuck in the open position, so that when the ice maker calls for water, the water will come out of the water dispenser as well.
For water to fill the ice tray or to be dispensed, two valves need to be operated.
There is a main water inlet valve (see Valve and water tube parts diagram part # 619A) which is operated in conjunction with either the water dispenser valve or the ice fill valve (Door parts diagram in above link, part # 619B & 619C), depending on what function is being used at the time
Here's the service manual for the refrigerator that may help.
On p.44 is describes how to test if the valves are electrically OK but this doesn't mean that they are mechanically OK.
On p.26 there's a schematic that shows the board connections for the 3 valves that may also help.
Note: The main water inlet valve is known as the water pilot valve in the manual
If a valve is faulty, search online using the part number for the valve (as shown in the supplier link) to find other suppliers that may suit you better.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chip Abrams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 26
