跳转到主内容
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
88 个问题 查看全部
Can I swap my logic board into a 2018 A1990 housing and use its parts?
I know the screen is compatible, but how about all the other hardware? I only ask because i've found a faulty A1990 from 2018 and the housing is in better condition that mine, and I need a new screen either way. Don't want to go all the way through the process to find it's not compatible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Swapping a logic board into a different housing might not work as smoothly as you hope. Logic boards and other components are designed to work specifically with the housing and components they were originally paired with. Compatibility issues could arise due to differences in connectors, sizes, and placements. It's generally recommended to use components within their intended configurations to ensure proper functionality.
这个答案有帮助吗?
得分 0
2条评论:
Should I just take the screen of the other housing and only replace that then? As it's compatible being A1990
完成的
If the screen from the other A1990 housing is compatible and matches the specifications of your device, you might be able to replace just the screen. However, keep in mind that even though the housing is the same model, there can still be variations in screen connectors, display technologies, and other factors that could affect compatibility. It's important to research and ensure that the screen you're considering is a proper match for your device before attempting the replacement. If you're not confident in your ability to perform the replacement, it's advisable to seek professional assistance to avoid any potential damage.
完成的
添加一条评论
添加你的答案
Bradley Moon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 52
