跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
Why does my iPod keep booting into diagnostics and wont let me out?
I just replaced my screen and battery on my Ipod and now it keeps booting into diagnostics (which I did and everything is working perfectly fine) and it wont let me out of diagnostics mode.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Does it boot back into diagnostic mode after a hard reset? Hold the "menu" and center button for ~10 seconds and that should reboot the device.
If that doesn't do it, maybe let the battery die by keeping it in debug mode off of a charger, and see if recharging it gets it to boot up normally.
这个答案有帮助吗?
得分 0
4条评论:
I tried this. It reset, then kicked me back into diagnostics. I tried with battery power, i tried with just wall power with no battery connected, i tries with firewire, nothing. just back to diagnostics.
完成的
@catdge You might have to restore the iPod, which will re-install the operating system and hopefully address whatever issue is causing it to boot into diagnostics. There's a decent iFixit guide on this process here: 如何进入DFU模式并还原iPod
完成的
I will try that.
完成的
Just note that this will delete all data on the device, definitely the brute force option. If this doesn't do it, it's probably time to re-open the device and check for damage, missing grounds, etc... Something simple like a stuck button or disconnected cable shouldn't cause it to boot into diagnostics.
完成的
添加一条评论
添加你的答案
Catdge 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 20
总计 82
