跳转到主内容
The Huawei P smart is an Android smartphone released in January 2019 by Huawei, a Chinese electronics manufacturer. It was released in 32 GB and 64 GB versions and includes hybrid Dual SIM capabilities.
19 个问题 查看全部
Screen is coming away from body of phone, what adhesive to use?
My P Smarts screen is coming away on the top right corner. The screen itself appears undamaged. What type of adhesive should I use to reattach it? Also would I need to remove the screen and clean any current adhesive layers for this, or is simply applying a little bit of glue in the gap and applying some pressure enough?
Cheers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Before doing anything, make sure your battery is fine, as a swollen battery is the most common reason for a popped screen.
这个答案有帮助吗?
得分 0
1条评论:
It's the end of the phone opposite the battery and there is a slight bit of damage to the actual casing of the phone on the same corner from when I dropped it ages ago so I think it's just the screen coming away as opposed to the battery being swollen. Battery life is still pretty good and it doesn't really get warm particularly. I'll check that when the time comes but regardless if the battery is damaged I'd replace it with a new one instead of getting a new phone anyway so some adhesive for the screen would still be needed.
完成的
添加一条评论
添加你的答案
OverlyFluffyDoge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 129
