跳转到主内容
Problem to connect with wifi and hotspots
My mobile wifi connection is working very bad nowadays, i am not able to connect to any wifi connection expect "5GHz" connection, even it is not allowing me to connect with others mobile hotspot connection and I'm also not able to give someone my hotspot connection, even is connecting range is also seem too much short.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @rohit33152
Try using the phone as close as possible to the network WiFi router or hotspot i.e. <10cm, and check if there's a good, stable connection.
If so it may be a loose or faulty antenna connection in the phone.
Here's a teardown video that will help.
At 4:07 minutes into the video, you can see one end of the antenna cable as it is being disconnected from the systemboard.
At 9:02 minutes the other end of the antenna is seen being disconnected from the charge port board.
If the antenna is OK, here's an image of the WiFi troubleshooting flowchart, from the service manual that may help.
(click on image to enlarge)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rohit 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 123
