跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
20 个问题 查看全部
Why is my phone overheating after screen replacement?
My phone was run over today I had to have a screen replacement. My face ID does not no longer work and my phone is heating up like crazy. This has never happened
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Was it heating up like that before the screen replacement?
完成的
Did you transfer the earpiece speaker from the old screen to the new? (its paired)
Also did you replace it with an LCD or an OLED?
LCD on OLED devices can lead to iphones overheating.
完成的
'It's been run over', probably the reason it's overheating.
完成的
@strongbow Ah that too. Battery may be damaged, or something could have happened on board.
They should check if the board is bent.
完成的
添加一条评论
1个答案
最有帮助的答案
As @luatech mentioned, replacing the wrong screen type may lead to overheating. Also check if you may have a damaged battery and/or charging port. If the problem persists it may be advisable to open your phone with the iPhone 12 屏幕更换 guide and check. If needed that guide provides you with all the needed tools. Best of luck^-^
这个答案有帮助吗?
得分 1
2条评论:
Yep!
If you buy screen replacements don't use sites such as ebay or aliexpress, they may be enticing because they are cheap and may even say OLED, but they will end up being LCD.
You can buy quality OLED screen replacements from:
IFIXIT: https://www.ifixit.com/Store
InjuredGadgets: https://www.injuredgadgets.com/
MobileSentrix: https://www.mobilesentrix.com/
Headlane: https://shop.headlane.co.uk/
Buy from reputable sites such as IFIXIT and you will get quality replacements.
Your battery may also be bad/low quality, you can also buy reputable batteries if needed from these sites.
Good Luck!
完成的
I bought regular screen from mobilesentrix. Can this cause this since it’s not oled.
完成的
添加一条评论
添加你的答案
Sarah-leigh Robson 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 67
过去 30 天: 212
总计 8,747
