跳转到主内容
加入维修社区 - 创建账户
Apple 在 2020 年十月更新了 iPad Air 平板电脑,其采用 A14 Boinic 处理器,10.9英寸屏幕,全新外观设计,以及内置在按键中的触控ID。
iPad Air 4 screen covered in lines after battery replacement
I used the ifixit kit to replace the battery on my iPad Air 4 but when I put the screen back on and powered it on it was covered in lines. It still responded to different external inputs from manually resetting or turning it on and off but it was still just lines going along the length of the screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Can you post a picture of what it looks like? You can add photos right into your original question.
由完成的
@flannelist oh thank you I just added one
由完成的
Were you able to solve the issue? I recently dropped my iPad and am experiencing the same issue.
由完成的
添加一条评论
1个答案
已选择的解决方案
Having a look at your photo, this doesn't seem like display damage, which is good. But something is clearly not working. I have a couple of thoughts, but based on your description that you have replaced the battery, I might hazard that something around the display connector got nudged during the repair.
I would make certain the cables are connected soundly, if that still doesn't fix it, do a careful inspection of your work. You can peel up the sticker around the display connector to make sure everything looks normal
Of the two connectors that come from the display, the one in question is the one closer to the bottom edge of the board.
这个答案有帮助吗?
得分 1
3条评论:
I’ll try look for anything messed up but I don't know exactly what I’m looking for would it be helpful if I posted a pic of the inside aswell?
由完成的
@herosbounty27 Absolutely! I know it’s hard when you’re not sure quite what you’re looking at. Mostly I would just look to make sure that things seem solidly in place. You might need some magnification since those components are quite small. The connector or the cable could also be suspect.
由完成的
@flannelist oki I added a picture but I’ll also look myself. is there any possibility it could be caused by dust on the connector or something easily fixable like that?
由完成的
添加一条评论
添加你的答案
herosbounty 27 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 564
