My phone is lagging
When I start the phone the it start lagging
Hi @realmec11
Start the phone in safe mode and check performance.
If it is OK i.e. no lagging, then a downloaded app may be the cause of the problem. The trick is to find out which one is the culprit.
You will need to uninstall each downloaded app one by one and test the phone in normal mode between each uninstall. When it works OK in normal mode, the last downloaded app that you uninstalled was the cause of the problem.
A downloaded app is one that you downloaded and installed and wasn't pre-installed on the phone already.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 42
总计 369
6条评论
No sometimes lagging
由 Najilnavas2 完成的
Yes i have this problem every day
由 Shyam 完成的
Auto switch off mobile app not open
由 Realms c12 完成的
由 Ram Nishad 完成的
laggings realme c11 phone
由 Realme c11 完成的
显示更多的1条评论
