跳转到主内容
The 5th Generation iPad Air was announced on March 8, 2022. It features the M1 chip and 5G connectivity.
17 个问题 查看全部
What is the iPad Air 5th Gen battery capacity in mAh?
iPad Air 5th Gen tech specs say the battery is 28.6 Wh, but with no voltage specified I can't calculate the mAh to compare the battery to other devices. Does iFixIt know what the mAh is for the installed battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The Apple A2742 battery is marked 3.8 Volts, 28.93Wh, 7606mAh.
You can read it directly on the battery in the iPad Air (5th Generation) Teardown video at time code 5:36
这个答案有帮助吗?
得分 2
添加一条评论
The iPad Air 5th Generation, a device I am familiar with, regarding the battery capacity of the iPad Air 5th Gen, it has a battery capacity of approximately 32.4 watt-hours or 8827 milliampere-hours (mAh).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Manly 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 182
总计 2,537
