跳转到主内容
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 个问题 查看全部
My Samsung Galaxy s2 is not charging
I've had this phone for many years and I've gone back to it to fix it many times but never managed to do so
So basically this phone has a changing problem sometimes it did others it didn't charge and after a while it stop charging completely i thought buying a new replacement charging port will do the trick i bought one and still nothing no charge
I was thinking it might be the battery but if it was the battery wouldn't it stop charging in the first place because when i moved the Cable a bit it was charging but i have no idea
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @ellusion
If the battery hasn't been recharged for a long while then most probably it has become depleted beyond recovery and needs to be replaced.
If you want to check if it is getting power to charge, here's the charging flowchart from the service manual for the phone.
On p.37 is the schematic for the charging circuit and p.28-p.29 have the board layout.
There's also a parts list on p.9-p.18
Hopefully this will help you to find out what's wrong.
这个答案有帮助吗?
得分 2
3条评论:
Thank you so much kind sir
完成的
@ellusion
Thanks for the feedback.
For some strange reason the ifixit spam iRobot marked your comments as spam and deleted them and has deducted 100 rep pts for every deletion.
I have restored your lost rep points and deleted the duplicate comments.
Just tag my user name (under my avatar) in a comment/answer or question to contact me if it occurs again and I'll pass it on to the admin.
Cheers
Moderator
完成的
@jayeff thank you so much my internet is slow and sometimes the comment gets send 2 times and it's the second time this has happened
完成的
添加一条评论
添加你的答案
Ellusion 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 130
