跳转到主内容
Repair information, service manuals, and troubleshooting help for refrigerators manufactured by LG Electronics.
32 个问题 查看全部
What part is causing my fridge to trip breaker as soon as I plug it in
So my fridge LSC27910ST
instantly trips breaker when plugged in. I discovered if I unplugged the defrost thermistor inside the freezer that the fridge will run again. Figuring a bad thermistor, but I am getting the normal expected resistance readings when I test the thermistor. But if I plug it back in, the fridge shorts the breaker instantly. What related part would cause this to trip? The heater element also has normal resistance readings. Is it the board? If so, can the board be repaired?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
So, it was the defrost heater. Unplugging the thermistor sensor essentially “unplugs” the heater, so I was confused. After putting in the new coil, everything is working fine.
这个答案有帮助吗?
得分 0
添加一条评论
Hi @johnrodi
Have you checked the fuse in the plug of the fridge as a faulty fuse can sometimes trip the breaker
这个答案有帮助吗?
得分 0
1条评论:
Can’t be that as my fridge is working right now with the defrost thermistor harness unplugged.
完成的
添加一条评论
添加你的答案
John Rodi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 30
