跳转到主内容
Why my laptop is not charging?
Whenever I open my laptop it doesn't show anything on the screen even it didn't open, as I plugin the charger my laptop open immediately and show me a warning message about power adapt. Is this a battery problem or my power charging adapter is weak?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@arz64bs Older Dell laptops have a little pin in the charger tip that makes contact with the charging port to determine wattage.
If the pin is bent or missing, the wattage cannot be determined and the battery will not charge.
Visually inspect the charger tip and if the tip is bent, carefully bend it back (while the charger is unplugged on both ends and with a non-metal object).
If the tip is broken, it usually will be cheaper to buy a used charger than fix it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Arz64 -BS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 10
总计 115
