跳转到主内容
Repair and disassembly information for the fourth-gen iPad Pro 12.9". Announced and released in March of 2020. Model A2229.
26 个问题 查看全部
This board is toast right?
So I have a customer who brought me an iPad Pro and it's literally stuck on the apple logo. No Boot looping, just solid logo for eternity. It will boot into DFU mode, but not Recovery Mode and when it does, it's not recognized by Mac or PC.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Have you opened up the device? I know with iPads, that is easier said than done but in this case may give you a better idea. Stuck on Apple logo usually has something to do with the OS. Or as Dan mentioned, it could absolutely be the NAND storage.
That being said, "it's not a board problem until you're sure it's not a parts problem." I would want to at least look at the device's internals. This also smacks of potential liquid damage to me. Which will be much easier to spot if you look at the inside. But I also realize that's a lot of work for what may end up being. "Welp. The board is fried,"
这个答案有帮助吗?
得分 2
添加一条评论
This sounds like the flash has failed. Replacing the chips is not trivial but could be a win if the storage was on the lean side which can explain why the chips died from excessive over-writing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
rickcostel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 43
