跳转到主内容
Released in December 2017, Business focused laptops with, 8th Gen Intel processors.
6 个问题 查看全部
Can’t record two audios on Skype call with a thirdy-party application
Good day! So my job requires me to record a call on Skype with a third-party application. When i begin recording the call, it would catch both my voice and the other line only for first 5 mins after that i couldn’t hear my voice anymore just the other line. What should I do? Should I upgrade my processor?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi there!
There could be a few reasons why you are unable to record two audios on a Skype call with a third-party application. One possibility is that the third-party application is not compatible with Skype. Another possibility is that your computer is not powerful enough to record two audio streams simultaneously.
To troubleshoot the issue, you can try the following:
  1. Make sure that the third-party application is compatible with Skype. You can check the application's website or documentation for more information.
  2. Check your computer's specifications. Make sure that your computer has enough RAM and processing power to record two audio streams simultaneously.
  3. Try using a different third-party application. There are many different screen recorders available, so you may be able to find one that is compatible with Skype and that can record two audio streams simultaneously.
  4. Upgrade your processor. If your computer's processor is not powerful enough, you may need to upgrade it in order to record two audio streams simultaneously.
If you have tried all of the above and you are still having problems, you can contact the developer of the third-party application or the manufacturer of your computer for help.
Here are some third-party screen recorders that you can try
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hiroshi Ikeda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 29
