跳转到主内容
A 20" monitor released in March 2012 by Acer, model S200HL
7 个问题 查看全部
Why Monitor not working it shows an orange shade through,earlier it wa
Why Monitor not working it shows an orange shade,earlier it was showing vertical lines also.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
  1. Check Cables and Connections:
Ensure that all cables connecting your monitor to the computer or other devices are securely plugged in. Sometimes, a loose cable connection can lead to display problems.
  1. Test on Another Device:
If possible, connect your monitor to another device (such as a different computer or laptop) to see if the issue persists. This will help determine whether the problem lies with the monitor or the device it's connected to.
  1. Check Display Settings:
If you're using a computer, access the display settings and make sure the resolution and refresh rate are set correctly. Sometimes, incorrect settings can cause display abnormalities.
  1. Update Graphics Drivers:
Outdated or corrupted graphics drivers can also lead to display issues. Make sure your graphics drivers are up to date. Visit the manufacturer's website to download and install the latest drivers for your graphics card.
  1. Try Different Ports:
If your monitor has multiple input ports (HDMI, DisplayPort, VGA, etc.), try connecting to a different port to see if the issue persists.
  1. Check for Physical Damage:
Inspect the monitor for any physical damage, such as a cracked screen or damaged cables. Physical damage could be causing the display problems.
  1. Reset Monitor Settings:
Some monitors have a built-in reset option that restores the settings to their default values. Check your monitor's manual to see if there's a reset option and try using it.
  1. Test in Safe Mode:
Boot your computer into Safe Mode and see if the display issue still occurs. Safe Mode loads minimal drivers and can help determine if the problem is related to software or drivers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JSA 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 16
