跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
243 个问题 查看全部
iPhone SE 2020 battery swap
Hello,
I want to try do an experiment if it’s possible.
I am wondering if I can swap the battery from the 2022 model into my 2020 model. Since the newer model has better mAh / battery capacity.
I know the connectors are different but could it work if I were to spot weld the BMS board from my original battery on to a replacement battery from the newer model ? Can’t find any higher capacity batteries for my phone since most are a scam.
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
If you spot weld it and you know how to do it good i don't see their being a problem but be careful you need special equipment for this repair
这个答案有帮助吗?
得分 1
4条评论:
Which equipment are you talking about if I can ask for some advice if I am missing something
完成的
First check if the voltage and ampere input and output of the batterys are the same then you are ok to move forward just know that apple is trying so hard for you not to be able to fix your battery so you will need a special device to read your battery go here he knows more than I do https://youtu.be/EWCnGhlJJzg
完成的
Please give me a score if helped you in some way thank you!!
完成的
Please give me a score if I helped you in any way thank you!
完成的
添加一条评论
添加你的答案
Slacer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 79
