跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Remove a stripped Case Screw?
Well I was replacing the power supply on my ps3 and did not get very far. The screw on the top casing turns but won't come out. Any idea on how to get this screw out? Thanks so much/
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
To clarify, is the screw head stripped or do you think the screw threads are stripped? Each will have a different answer for methods of removal.
完成的
添加一条评论
2个答案
已选择的解决方案
That never happened to me with a PS3, but once on a PSP, once on a toy dog and once on an ancient laptop.
I tried to pry it carefully with pliers. To avoid scratching the plastic, I used the plastic pliers they give you with rubber office stamps.
However, in my ill fortune I was kinda lucky, as I found out that on the PSP the plastic thread was stripped, so pulling with the plastic pliers did the trick.
Have you tried also with magnetized screwdrivers? Do the other screws get out fine? On the ancient laptop, for example, I removed all the other screws, and pushed really lightly the top and bottom case, prying them with barely enough strengh to find out if the screw was still holding together. It didn't, but if it did, and if I had used too much strengh on it, I may have damaged the casing.
Also, the good old WD40 may be worth a shot, but I'd put it as a last resort card, and carefully applied. I used it once on a PSP, but then I managed to drop some in the innards, and got me quite a lot of time to clean all the mess.
As Philip said, a stripped screw may be pulled down in different ways according to the stripped part (screw threads on the screw, on the plastic casing or stripped head).
A careful use of plastic pliers may help you assessing the damage, allowing you to see if the screw budges or not.
Another attempt may be using a little bit of Krazy Glue to temporarily "fasten" screw and screwdriver, gaining more torque. However, there's still the risk of putting too much glue and leaving an unsightly blob.
I've also read about drilling the screw using a drill bit smaller than the screw itself, but as PS3 carries really small screws, and it's kind of a costly device, I'd avoid.
There are also specific screw extractors, and they sell them here.
Precision Screw Extractor Set
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm.图片
产品
$24.99
这个答案有帮助吗?
得分 2
添加一条评论
Take a nail and put it under the pull up and then I'll come out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Minhal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 57
总计 10,505
