跳转到主内容
Released 2007, identified as Satellite A215-***** (several variations, ex: A215-S7437)
Power LED and Charging LED on but laprop won't turn on
Whenever I connect the laptop charger the charging LED is on with power LED too but as i press the power button it doesn't on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Dear Chandan Jaiswal,
If you are experiencing issues with your keyboard, please check if your driver is installed. If not, visit the Toshiba website and download the appropriate driver for your keyboard. If you have already done this but it is still not working, it is possible that the LED lights on your keyboard are faulty and need to be replaced.
这个答案有帮助吗?
得分 0
1条评论:
@kaleb88022 do you think it is possible that this is the power on circuit? Would you recommend to check to see if there is power to the motherboard? Could the OP use an external keyboard to bypass a bad keyboard and how would the keyboard be causing this?
完成的
添加一条评论
添加你的答案
Chandan Jaiswal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 137
