@stevendugas just to clarify. It was running, then you pulled a spark plug wire and it died? Why did you pull that wire? Which Wire? A single spark plug wire should not be the cause of this. It should maybe run bad but should not turn off unless the coil pack got shorted out. what have you checked? Do you have spark when you crank the engine over?
由 oldturkey03 完成的 分享
