跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
20 个问题 查看全部
iPhone XS Max手机经常重启,有的时候会无限重启
我的手机有的时候经常重启,例如我正在使用着手机的时候突然重启,然后重启开机后电量就剩10%,然后这10%的电量可以用很长时间,但是实际电池电量是充满电后的电量,但是有的时候重启之后电量是正常的,有的时候重启之后电量是10%,这10%也不会往下掉一下文件是我的重启分析报告,希望有大神可以解答一下
以下文件是我的重启分析报告,希望有大神可以解答一下
http://152.136.59.93:8089/down/PRXrXOUkf...
以往使用情况:
之前手机原装电池也是会出现这种情况,但是重启的频率也很高,几乎和现在的重启频率一样,也是充满电玩,一会儿自动重启,然后重启之后电量还剩20%这20%的电量可以用很长时间,但是在20%的电量还会持续重启刚开始,我以为是电池的问题,所以更换了电池和电芯,但是更换完成,电池和电芯之后屏幕又出现了问题屏幕没有触摸反应,然后找维修师傅查看情况是因为主板的问题,然后又修复了一下主板,现在屏幕可以正常使用,但是问题依旧是经常性的重启手机刚开始,我让维修师傅查看了一下维修师傅说可能是因为电池电芯的问题,所以有更换了一块儿新的电池,但是问题还是所在,然后上维修师傅又检查了一下,但是找不到具体的原因在哪,因为重启的间隔时间没有规律
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I added in the first big of the panic log that I grabbed from your other post since that link did work.
This is still definitely in battery territory. It references the BMS (Battery Management System) multiple times and based on your description, I would wager the device is not getting good "gas gauge" data. That is to say, the information that tells the phone how charged the battery is is missing, or garbled. There could be some issues with the battery connector, or some of the components around the connector which assist in relaying this data to the CPU (the SMC specifically, as is mentioned here in the panic).
Some images of what the board looks like in the area of the battery connector would be helpful,
这个答案有帮助吗?
得分 2
5条评论:
First of all, thank you very much for your patience!
Yes, you guessed it right, my battery level was inaccurate.
However, I also tried to replace the whole battery before, but the problem still exists, so I think it should be ruled out because of the battery?
But at present, I have no alternative to solve my problem.
完成的
Thanks a lot for your answer.
In your reply I see that you indicate that there may be some issues with the battery's connector or around the connector.
If I understand it as the circuit board of the battery or some components around the circuit board, then I took it to the maintenance master to check the circuit board, but the maintenance master told me that there was no problem with the circuit board.
The suggestion of the maintenance master, let me try to replace the chip.
完成的
Because my mobile phone restarts irregularly, the only regular time is when charging at night, when I wake up in the morning, when I check the analysis log, the phone restarts many times, and the interval is about 1-2 times every few minutes. .
When I unplug my phone from the charger, it restarts erratically. Sometimes it restarts continuously, sometimes it takes 5-6 hours to restart.
完成的
My interpretation here is that I'm thinking there's a problem with the I2C bus used for communicating with the battery.
I pulled some schematics of the iPhone XS Max, and the BMS communicates over I2C0_SMC. That signal goes to a chip labelled USB-PD and another one labelled Yangtze Charger. It looks like there's a level shifter circuit right next to the battery and of course caps and resistors in the line.
Although I have reference designators for those components, I don't have a board file that shows me where they're physically located, at least not yet.
However, the other thing of interest is that those signals appear to go through the interposer, meaning they're transferring from the top board to the bottom board (or vice versa). So in addition to the possibility of a missing or damaged component, there's also the chance that the interposer has flexed and broken some pads. That, of course, will take expert-level microsoldering repair, unfortunately if that's the problem.
完成的
@dadibrokeit That sounds very much like I would expect. I can look up locations if need be. But the XS Max board is extra weird. There is a small section of the board around the SIM tray that goes to only one level of board and then another small section at the bottom that's sandwich board again. I feel like all the charging components are in that segment.
@ownstupid I would definitely be looking into Yangtze if that wasn't the chip that was already recommended to replace (assuming you replaced it).
完成的
添加一条评论
添加你的答案
OwnStupid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 164
