Are you trying to say that the switch does not activate the blower motor for the AC? If so, you first need to check for a blown fuse. If the fuse is ok, check to see if you have 12 Volts coming into the AC switch and out to the blower motor, you will need a wiring diagram to identify the wires. That will eliminate two possible causes for the problem, the fuse, and the switch. Beyond that, you will need a service manual for the specific make and model of the vehicle.
由 John Dragon 完成的
