My laptop is not on when I click power button.
my laptop is not on when i click power button.
Well I will suggest you to check out this video: https://www.youtube.com/watch?v=z0ebMAcw...
If this not help you out in fixing the issue then you can also check out this for more solution: https://www.systweak.com/blogs/fix-lapto...
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 105
@sandeepkum59501 Does the charge light come on when you plug the charger in?
由 Dany 完成的
Charger light is on. Laptop still not on when click power button. Battery built in. I cant remove battery to try power on without battery while pluging the charger cable.
由 farid daud 完成的
