跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
327 个问题 查看全部
The screen of my laptop have this glitch effect?
The screen of my laptop is having a sort of glitch effect, i’ve tried clearing my SMC, udpated my software etc. But nothing helps. I saw somewhere that it could be the problem of the T-CON and needs to be replaced.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Could be the TCON, or could be the flex cables. This sort of thing is very common with "Dustgate." Does the behavior change at all depending on the angle of your screen?
这个答案有帮助吗?
得分 1
4条评论:
I’ve tried the angle from full open till just closed but it’s still happening.
完成的
@indymeermans Ultimately, you're likely going to have to replace the display for either of those issues, unless you have microsoldering know-how, or can find a shop that will take a look.
"Dustgate" is an issue where small bits of debris get into the flex cables for the display. They burrow their way into the cable with repeat opening and closing. It's repairable, but tedious and delicate. Because these cables are not designed to be replaced, you need to repair the existing cable somehow.,
完成的
@flannelist Ohh okay! I will look for a display replacement, not by a shop but I want to learn it myself. The facts that the cables are so fragile, they are gonna break anyway soon if I would solder it. :/
I've first checked with a repair shop what the problem was but they told me they had to replace the logic board... :p
Is there anyway to prevent this in the future or is this just a flawless mistake from apple that you can't prevent it.
完成的
@indymeermans It could be the board, but I would try to connect it to an external monitor. If the video there looks normal, the board is unlikely to be the cause. I am much more likely to think the display.
Prevention is mostly just keeping your device internals clean, especially the hinge area. Dust gets caught in that area because it's where it gets exhausted from the computer, so if there's no dust to blow around, dust can't get caught.
完成的
添加一条评论
添加你的答案
Indy Meermans 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 141
