跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
Only digitizer working. LCD is blank
I had my iphone XR fixed a couple of times in a shady place. The last time I got it back the screen worked for a while and then just went black and I thought it was fully out. But after a couple of tries I realized that the digitizer is responding I can turn on the flashlight from the lock screen and it's just that LCD is not displaying anything.
I tried opening it up after I bought ifixit kit and just basically removing the LCD and digitizer cables. Then pushing through some air to check for dusts in connectors and putting back in hoping that the place just didn't put it back together properly. But the issue persists. Is there a good way to pinpoint the issue here? Whether it's a connector or the LCD? Or is the best way just buy another screen and try it again?
Another small thing to keep in mind I just tried it by putting cables back in not not screwing back in the brackets if that makes any difference...but I doubt it :) Thanks for any assistance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
i think the best route is to just buy a new screen completely to see if this is a board level issue or just the screen, and you cant really repair the screen yourself at home, so unfortunately you'd have to replace it either way :(
do you seen any possible bent pins on the board?
iPhone XR Screen
hope this helps!
Replace a screen compatible with iPhone XR. Includes all of the small parts pre-installed in the assembly, saving time and increasing the quality of your repair. 6.1 inch IPS LCD 828 x 1792 Display.图片
产品
iPhone XR Screen
$66.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ignas Avižinis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 66
