跳转到主内容
Bluetooth, google play compatible, 8 GB of storage available.
18 个问题 查看全部
I Have an LG Rebel LML212VL Glass is Starting to Lift up at Bottom fix
Can I just lift the rest of the screen up to glue it without taking it apart. I don't see the two clasps one on each side of this model that holds in the glass on this video? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
i have never worked on this model before, the glass could be bonded to the lcd, in which case you would probably need to remove the screen completely and reattach it using an adhesive like b7000
这个答案有帮助吗?
得分 1
4条评论:
Do you know of a you tube video that shows you EXACTLY how to do this for ONLY the LML212VL? Thanks
完成的
Daniel Thank You for the website, but I found out what was wrong, I took out the Battery and it was slightly Swollen so I had a spare battery for it and when I put it in, the phone was Perfect again. The glass No longer is popping up at the bottom. Thank God, Swollen Batteries can actually explode and start a fire. I think I was charging it way too much. I will be more careful in the future. I will check the battery every few months to make sure. Case Solved: Thanks again
完成的
@tomgenn the age of the battery can cause that aswell, lithium batteries only have few years, so 8 years wasnt bad
完成的
添加一条评论
添加你的答案
Tom Genn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 53
