跳转到主内容
加入维修社区 - 创建账户
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
Problem connecting cpu and periphals
Hi, so i bought an Iphone 11 to change the screen and use it, but its restarting every three minutes, then I checked crash analysis and found two Missing sensor(s), sometimes its Prs0, but sometimes there's Prs0, mic2, should i try to replace them both, or what should I do? Can you help me? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
but in most times there is only Prs0
完成的
添加一条评论
1个答案
最有帮助的答案
Those sensors are on different assemblies so in my opinion you're looking at replacing both the lightning port flex assembly (Prs0) and the flash/power button flex assembly (mic2). You'd definitely have to start with the charging port assembly, and since you're going to be in there anyway it doesn't make any sense not to replace the flash/power cable at the same time.
iPhone 11 Lightning Connector Assembly Replacement - iFixit Repair Guide
Manuales / Apple iPhone 11 / Power button, flash and top microphone
If you don't do them both, Murphy's law guarantees you'll have to go back in and do the other one.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Oris Koris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 364
