跳转到主内容
加入维修社区 - 创建账户
2021年10月发布的14英寸MacBook Pro的维修指南和拆解信息,该产品采用苹果设计的M1 Pro和M1 Max SoC,型号为A2442。
Right Fan Not Working
Hey guys,
Right fan of my girlfriends' macbook 14 pro 2021 is not working. Actually it tries to work under load but it increases the fan speed from 0 to 20k and beeps when I can with macs fan control. It keeps beeping periodically. The question is, if I remove the back cover and disconnect right fan will the mac start? The most demanding app she is using is zoom, on average she works with chrome and spreadsheets. As she is using it like this for 4 months without right fan, I don't think it will be a problem for disconnecting the right fan. But the question is if it will start the mac or not without the fan. Before removing the cover I wanted to ask, I will be glad if anyone knows the answer.
Best
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The beeps is telling you something! Instead of second guessing disconnecting the fan will fix this how about getting a better idea what the problem is.
So… Restart the system and press the D key it will enter into the onboard diagnostics. Let’s see what it tells you.
Reference: Mac startup key combinations
And no disconnecting the fan is not a wise action as SMC will loos access to the fans Tach and do two things ramp up the fans speed as well as lower the CPUs clocking to prevent damage.
All it will do is confuse you on what’s needed to truly fix your system.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shinanai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 271
