跳转到主内容
Macbook Pro Replacement keyboard - F Keys are in the wrong place
Had Apple fix a bunch of laptops for me
One of them had they keyboard replaced but is now sporting the up to date keyboard layout so the F keys are now in the wrong place
Is there an easy way to re-assign the keys?
The System (Snow Leopard) was installed with the previous keyboard so presumably mapped the keys during installation? (I'm just guessing here)
I can't see anywhere in the keyboard or expose system prefs to reassign the volume keys from F3/4/5 to further up the keyboard
Any advice thankfully received
I could of course physically remove the keys and replace them in the 'correct' place for the current system setup but is there an easier way?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Delete the Library/Preferences/com.apple.keyboardtype.plist file, log out or restart.
这个答案有帮助吗?
得分 4
2条评论:
Thanks machead3 but that file doesn't appear to exist under snowleopard
完成的
That's on my copy! System Preferences -> Language & Text (Input Sources)
完成的
添加一条评论
I would at least try running an installation of snow leopard, it should recognize the keyboard attached and set everything correctly - should be the least work of all.
这个答案有帮助吗?
得分 1
添加一条评论
Negative...the file does exist in Snow leopard, deleting and restarting has no effect on the incorrectly mapped keys.
这个答案有帮助吗?
得分 0
添加一条评论
It may be that you have a keyboard from the last Macbook Pro model, A1260. Apple switched the F-key locations on that model. It's unlikely that they would, but it may be something to check. Best of luck!
这个答案有帮助吗?
得分 0
添加一条评论
The apple keyboard keys are removable so you can just lift up and move it in to the correct location.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
FMS 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 6,683
