跳转到主内容
三星公司于2018年3月发布的旗舰手机,盖乐世 S9。
Why does my phone show moisture detected warning though it is dry
I had just used my phone till it ran out if battery.And just when i grabbed my charger and tried charging my phone it started showing the moisture detected warning.Neither the phone nor the charger had never been in contact with water or other liquid substance that day. I tried many ways to fix it including air drying it for few days but still it shows that moisture detected warning when plugging my charger. Please help me fix this issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
the moisture detection shows up if the port and/or the cable is dirty or just corroded enough that they don't quite give the expected amount of power.
Try cleaning the port with a toothbrush and some isopropyl alcohol. If you have a magnifying glass and a good lightsource you might even be able to see your problem
And if that does not help. You might need to replace the port by yourself or using a repair shop.
Ps. Some people claim that they bypassed the warning by plugging it in, then force restarting the phone. (Power button + volume down) but only you can confirm if that does the trick.
Good luck (⁠•⁠‿⁠•⁠)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tori 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 71
总计 7,072
