跳转到主内容
The Dell Latitude Series is designed mainly for professional use. This model is a 14" laptop released by Dell in 2018. The Dell Latitude 5490 emphasizes durability, portability, security, and is known for its long-life cycle.
Why is my keyboard typing wrong words
Whenever i press 7 it prints y7, whenever i press y it prints 7, whenever i press caps locks it prints 2 ,@ not typing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
@daniyalnaz89220 Did you spill anything on the keyboard? You can try an external keyboard, if the same problem doesnt come up with that, then the problem will be solved with a keyboard replacement.
这个答案有帮助吗?
得分 0
添加一条评论
Well Go to Control Panel and select the group Clock, Language, Region. Select language and choose Advanced Settings. Locate the option Override on Default Input Method and select preferred language from the drop-down menu. Set the Override for Windows Display Language to the same language, hit OK, and restart your computer.
这个答案有帮助吗?
得分 0
添加一条评论
Maybe the keys were swapped out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniyal Nazir Hajam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 117
