Ps4 beeps once when I turn it on and shuts down 👎
First my ps4 was liquid damaged and the liquid went into its power supply and there was a short circuit I gave it to a repair shop and the changed power supply's ICs and it worked fine in the shop when we tested it I bring it back home and it beeps once and turns off then I took it again to the shop and it worked gust fine but again when I took it back home it still beeps once and turns off. I have tried everything like, checking it's live and neutral wires and plugging it into every power outlet in home and it still happens. Plzz help me
Don’t mean to sound patronising but have you tried using a different power lead. Often the simple solutions are overlooked.
由 Frankie Vaughan 完成的
@frankievaughan the shop keeper surely did
由 M. Irfan 完成的
Unless I read the post wrong, it works in shop? Using a different power lead to that at home.
@frankievaughan ok
由 M. Irfan 完成的
@frankievaughan hey mate I had a question that I changed the wire and it worked but the shopkeeper turned it on by pressing eject button than power button than I came home and turned it on by doing that with my wire and it worked . Is there any secret method
由 M. Irfan 完成的
显示更多的1条评论
