跳转到主内容
Repair and troubleshooting documentation for Frigidaire dishwashers.
Frigidaire Gallery dishwasher fgip2468uf
This dishwasher has started to not drain in all wash cycles. I can put it in diagnosic mode and fill it with water then make the pump drain and it's fine. If we put it in normal rinse mode it drains just fine. I've made sure the filter is clean and also made sure nothing is in the drain area by the little ball.
Any suggestions would be greatly appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @ggoldsm590
Do you get an error code if you run the diagnostic service test #7 i.e. drain test?
If you haven't already got it here's the service data sheet that may help.
这个答案有帮助吗?
得分 1
5条评论:
No the drain test runs just fine. This it what's so confusing
完成的
@ggoldsm590
Wonder if there's a problem with the drain flapper valve.
It supposed to prevent backflow from the drain although why the dishwasher works OK in rinse only idk unless there's a problem with the household drain that the dishwasher drain pipe is connected to is not draining quickly enough
完成的
No issue with the kitchen drain pipe at all. It's just very weird
完成的
@ggoldsm590
Maybe worth checking the flapper anyway just in case it is sticking closed
完成的
I'll pull the unit out and check it this weekend
完成的
添加一条评论
添加你的答案
Gary Goldsmith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 389
