跳转到主内容
Repair guides and disassembly information for the Samsung Galaxy A51 Android smartphone. Released in January of 2020.
103 个问题 查看全部
Fully functional display, but only for Samsung boot screen
Why would a Samsung Galaxy A51 be fully functional, but display absolutely nothing on the screen EXCEPT for the startup logo, recovery menu and the charging animation when the phone is switched off?
Got someone's phone where the display stopped working a few months ago, except for the three cases as mentioned above. They factory resetted it at some company.
Went through the painful process of switching on TalkBack and doing the startup wizard, switching on USB debugging in settings, then connecting the command line tool "scrcpy" and being able to fully view the screen on my Macbook.
Now how would I go about restoring this phone's display on its own, rather than just operating it through my Macbook, given that the display works during the very start of the boot cycle as mentioned above?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
hello, did you do any updates?
because it could be that some files in the logs got corrupted during the update and in that case the only attempt you can make is to do a softwar reset from scratch by reinstalling the firmware with third-party software such as odin
UTILIZZO ODIN
这个答案有帮助吗?
得分 0
添加一条评论
because it could be that some files in the logs got corrupted during the update and in that case the only attempt you can make is to do a softwer reset from scratch by reinstalling the firmware with third-party software such as odin
UTILIZZO ODIN
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
1条评论:
I have already flashed a brand new Android build on it and it runs perfectly fine
完成的
添加一条评论
添加你的答案
C.J. Meyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 50
