跳转到主内容
HP ProBook 4320t manufactured in May of 2010.
How will plug my laptop to external display?
how will i be able to plug my laptop to external display?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@samuelotuo there's a HDMI and a VGA port on the left side of your laptop. You can use either, depending on which one your external display supports. A more modern display will use HDMI, older displays will use VGA.
You can check for the ports on the display too. Match the port on the display to the port on the laptop and use the appropriate cable (HDMI/VGA) to connect the two.
这个答案有帮助吗?
得分 1
2条评论:
should connect it with external hard drive?
完成的
No, you need to connect it with a monitor or a TV.
完成的
添加一条评论
添加你的答案
Samuel Otuo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 98
