跳转到主内容
2021年10月发布的14英寸MacBook Pro的维修指南和拆解信息,该产品采用苹果设计的M1 Pro和M1 Max SoC,型号为A2442。
75 个问题 查看全部
Keyboard not working, but backlight + trackpad work fine
My MBP 14" (2021) has an issue where the keyboard is not responsive, except for the power button.
The backlight on the keyboard works fine and so does the trackpad. The keys are not responsive however.
Running diagnostics (using an external wired keyboard to boot in) shows no issues.
I have read that other people resolved this issue by replacing the trackpad cable, is this likely to work? Also, If I carry out this repair myself, will it be obvious to future Apple techs that a user did it, causing them to refuse future service?
I will take it to the Apple Store first but I am concerned they will charge a huge bill to replace half the laptop!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This model uses independent cable connections for the keyboard and the trackpad. The older 13” model used a daisy chain setup which had a single cable from the logic board and then the keyboard was connected to the trackpad.
So in this case replacing the trackpad cable won’t alter the keyboard.
So why did the keyboard stop working? Did you have a spill or drop something onto the keyboard. Without knowing I would just be guessing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SamN 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 17
总计 59
