跳转到主内容
加入维修社区 - 创建账户
The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
Why is my screen showing distorted images/ colors?
请参阅图像内容:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论:
I have tried different power supplies, RF cable and R/W/Y composite cables. No difference. Also cleaned cartridges and pins in the console.
完成的
@talonrevenge Have the electrolytic capacitors on this console been replaced?
完成的
@andrewsawesome not that I am aware of.
完成的
@talonrevenge Have you cleaned the pins on the video connections or the cartridge connections?
完成的
@erelectronics yes I have cleaned them.
完成的
显示更多的2条评论
添加一条评论
1个答案
There are a few reasons why your screen might be showing distorted images or colors. Here are some of the most common reasons:
  • A faulty graphics card. The graphics card is responsible for displaying images on your screen. If the graphics card is faulty, it can cause distorted images or colors.
  • A loose or damaged cable. The cable that connects your monitor to your computer may be loose or damaged. This can cause distorted images or colors.
  • A problem with the monitor. The monitor itself may be faulty. This can cause distorted images or colors.
  • A software issue. A software issue, such as a driver problem, can also cause distorted images or colors.
Here are some things you can try to fix this:
  1. Check the graphics card. You can try updating the graphics card driver or rolling back the driver to a previous version. You can also try reseating the graphics card in the motherboard.
  2. Check the cable. Make sure that the cable that connects your monitor to your computer is properly seated and not damaged. You can also try using a different cable to see if that fixes the problem.
  3. Check the monitor. If you have another monitor, you can try connecting it to your computer to see if that fixes the problem. You can also try resetting the monitor to its factory settings.
  4. Check for software issues. You can try updating the drivers for your monitor or rolling back the drivers to a previous version. You can also try uninstalling and reinstalling the graphics card driver.
If you have tried all of these things and you are still having problems, you may need to contact a computer repair technician for help.
这个答案有帮助吗?
得分 0
1条评论:
This is a SNES not a computer. So not sure that if what you put applies to some degree or not here.
完成的
添加一条评论
添加你的答案
Talonrevenge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 391
