跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
376 个问题 查看全部
iPhone does not charge past a specific battery level
I use fast charging (of course genuine from Apple, 18W), but the strange thing I noticed is that it sometimes can't charge through a certain battery level (eg 10% after 30 minutes it's still 10%), it can also sometimes charge up to a certain battery level, but will be stopped at a different battery level, namely about 70% and 90%
The only fix is ​​that I have to restart the device for it to charge up
Also added that I replaced the battery for it, also genuine from Apple
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi, you need to change the charging system and retest again to see if the phone charges beyond the said percentages.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the reply, I also changed to another fast charger and the result is still the same
About restart, or perhaps reset, I tried it too and it's still the same
I still don't understand what you mean by "change the charging system", it could be replacing lightning port or replacing charger
完成的
添加一条评论
@kiyoshi1407 if the new battery is under Apple warranty, I'd recommend you take the phone back in for them to troubleshoot. It sounds like a bad battery they put in.
这个答案有帮助吗?
得分 1
2条评论:
Maybe it is, the battery is still under warranty so I will take it to an Apple center to change to another battery. I hope the lightning port isn't broken because it is expensive and very difficult to repair
完成的
@kiyoshi1407 It's not too awful to do, the part itself is also only around $20, the whole charging assembly is replaced.
完成的
添加一条评论
添加你的答案
Kiyoshi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 39
